SOURCE: Diesel fuel in homelite leaf blower !
this is not a problem
you need to remove all the fuel
and remove your spark plug add new fuel and with the spark plug out pull it over many times to purge the system now install a new spark plug and you will be fine
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
SOURCE: homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
SOURCE: My Homelite Mighty Lite 26b
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
