Am using a GE-29414-D universal remote. I want the codes to control Sony TRinitron TV model number KV-27S42
The codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Haven g e remot control universal ahy need de codes for magnavoz tv som bide
Need actual codes that will work
I have a ge universal remote model number 25003_v3 1334 and I can't find codes for it is a remote the we purchased 1 in Dec and identical one a few months before
