SOURCE: ECS RC415ST SKT 775 MOTHERBOARD MANUAL
RC415ST is a HP Motherboard Model. please check the model again
SOURCE: where to plug the f_panel power cable
No I do not.
ECS Support does though,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=830&CategoryID=1&MenuID=16&LanID=0
Click on the Download tab.
(Features / Specification / Download / FAQ / CPU / Memory )
Click on Manual
(Driver / BIOS / Manual )
Scroll to the bottom, click ON the country name nearest yours.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
Go to the Bottom/Middle of the page with your mouse cursor. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it -
Show Adobe Reader toolbar - will briefly appear)
The Zoom In icon ( + ) increases the view size, if you click on it.
The Zoom Out icon ( - ) decreases the view size.
The PDF file page number box is to the right of the Down Arrow.
The PDF file page numbers, and the motherboard manual page numbers, do Not match.
When I refer to a page it is the PDF file page.
If you know the page number you want, you can go page by page, using the Down Arrow to arrive at it,
Or;
1) Put your mouse cursor in the PDF file page number box,
left-click once. (Anything in the box is now highlighted in blue)
2) Type the page number
3) Press the Enter key.
Go to Page 10. Motherboard Components.
Motherboard installed in your computer;
Processor to the Top, Ram Memory slots to the Right, and white PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner. (8)
Go to Page 33. Front Panel header pinout.
The Front Panel header lies horizontal, and parallel to the bottom edge of the motherboard.
It is two rows of contact pins.
The TOP row is numbered EVEN.
The Bottom row is numbered ODD.
Starting from the LEFT side going towards the Right, for the Top row:
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting from the LEFT side going towards the Right, for the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the two wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It was for factory use.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Already gave a solution,
http://www.fixya.com/support/t13708962-plug_f_panel_power_cable
Regards,
joecoolvette
