Kenmore HE3T Washer Logo
A
Anonymous Posted on Jun 21, 2014
No power door locked, how to open door? - Kenmore HE3T Washer
1helpful
2answers
I have a 2000 chevy astro. All my doors lock and unlock except the two front doors. And my key fob won't lock or unlock any my doors. But the panic button still works,strange. Anybody else ever had an...
Service repair info. manual would be the place to start ,seeing how you have no clue .,or maybe a qualified repair shop. How are you going to fix it with out knowledge of how it works an what to check , --------------------------------------------------------------------------------
Power Door Locks Circuit Description
The power door locks are operated by reversible motors. The motors are found in the following locations:
• In each front door
• The side door
• The rear door
The PWR ACCY circuit breaker (30A) supplies voltage to the door lock motors.
If you move either power door lock switch, mounted in the front doors, the LOCK applies voltage to cavity F of the door lock relay. This energizes the lock coil in the relay. Current then flows through CKT 295 (GRY) directly to the following components:
• Both front door lock motors
• The side door lock motor
• The rear door lock motor (cargo doors only)
CKT 246/294 (TAN) provides the ground for the motors. The normally closed contacts of the UNLOCK then contacts the door lock relay.
If you move one of the door lock switches to UNLOCK the polarity of the system reverses. Current flows through the energized UNLOCK relay contacts. The LOCK relay contacts provide ground.
When the UNLOCK button is pressed once on the RKE transmitter, only the driver door unlocks. If it is pressed a second time within 5 seconds, all doors unlock.
If the side door is open, the side door jamb switch ground signal is opened/broken. If you move the door lock switch to LOCK while the side door is open, the following actions occur:
• The 2 front doors lock
• The rear door locks (cargo doors only)
When you close the side door, the door jamb switch closes. This closes the ground signal to the body control module {CKT 775 (PNK)}. A 5 second timer then starts in the module. After 5 seconds, cavity A4 connector C1 of the body control module supplies voltage to the door lock relay via CKT 195 (LT BLU). This energizes the door lock relay, which sends voltage to the door lock motors in order to lock the side door. Refer to Door Jamb Switches, Liftgate Strut Switch for a schematic of all door jamb switch inputs.
If the side door opens during this 5 seconds, the 5 seconds timer is reset. The locking pulse takes place at the end of the 5 seconds. Unlocking the door resets the 5 second timer in the body control module.
Use the following components in order to unlock the door lock system:
• The LH power door lock switch
• The RH power door lock switch
On vehicles equipped with cargo doors, the cargo door opener mechanically opens the door once the door lock system is unlocked. On vehicle equipped with a liftgate, the liftgate lock/unlock release switch (mechanical key) is added in order to serve the same function as the front power door lock switches. These functions locking and unlocking all doors, including the liftgate. Once the door lock system is unlocked, press the liftgate release switch in order to electrically open the liftgate and pull the handle in order to open the secondary latch.
Door opener
Make sure child safety lock-out is not engaged for this door. There is a latch in the door and it prevents the door from being opened from the interior.
Sorry I do not know the configuration within the door frame. You may or may not need more working room. Some seat bases are removeable and this would allow better access to all parts of the back door.
If you can reach the wire which goes to the electric door lock, you could test if power is going through the wire. If no power when the unlock button is hit, you must trace the wire back to the switch.
Now if you put a 12 volt power source through test wires and bypass the locking mechanism and directly power the individual door lock, it should be possible to set the door lock to an open position. This would allow you to open the door and continue servicing the inside of the door.
I have power to the door lock switches on the drivers door but the locks do not work nor does the back hatch or the switch at the back hatch that controls all the locks in the vehicle. Do the locks g
The power door lock system incorporates door lock switches on both front doors and on the RH D-pillar, door lock motors in all passenger doors and in the RR cargo door, a door lock relay and a door lock control module.
Power for the door lock switches and the door lock control module is supplied from the CIG LTR fuse 13 through CKT 640 (ORN). Power for the door lock relay is supplied from the PWR ACCY circuit breaker through CKT 540 (ORN). Ground for the door lock relay is supplied from G202 through CKT 150 (BLK) and ground for the door lock control module is supplied from G400 through CKT 150 (BLK).
The door lock motors are reversible and both sides are connected to the normally closed contacts of the door lock relay. Those contacts of the relay are connected to G202. When any of the door lock switches are placed in the lock position, voltage is supplied through CKT 195 (LT BLU) to the relay lock coil. Since the other side of the lock coil is connected to ground, the coil is energized and it pulls the lock contacts closed. Voltage is then supplied through CKT 295 (GRY) to all the door lock motors and the doors lock. The unlock function operates in much the same manner except that when any of the switches are placed in the unlock position, voltage is supplied through CKT 194 (WHT) to the unlock coil of the relay and CKT 294 (TAN) supplies voltage to the apposite side of the door lock motor and the doors unlock.
Door Lock Control Module Description
The door lock control module is used on vehicles equipped with cargo doors. The purpose of the module is to lock the cargo doors after a lock cycle has been commanded from any of the door lock switches with the cargo doors open. When the RH cargo door is open, the module receives a ground signal from the closed contacts of the rear door jamb switch on CKT 1897 (ORN/BLK) to G400. When a lock command is received, the module retains this input until it receives an open input from the rear door jamb switch. Then the module sends a lock command through CKT 194 (WHT) to the door lock relay and the doors lock.
Rear Cargo Doors Description
The power door lock motor will not operate unless the rear cargo doors are fully closed. The power door lock motor is in the right cargo door. The contactors are on the rear cargo door opening on the body and on the right cargo door.
1helpful
Power locks not locking on dodge stratus
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working ?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
Door will not open with handle or interior handle. The door lock unlocks and locks with the auto door lock
Central locking not working?
This will help.
Thanks.
Powerlock
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
All power door locks not working ?
This will help.
Thanks.
1999 Ford Windstar power door locks only work when key is turned on
This will help.
Thanks.
1helpful
97 Ford Explorer back doors won't open
A common problem with these are that the power door lock actuator freezes, and wont let the door unlock all the way,or the latch rusts up and again wont let door open, see if the lock arm is going up and down all the way, if not then try grabbing the lock with pliers and pulling up and then opening the door, or pull and push a few times then try to open the door, good luck.
2001 Jeep Cherokee sport. Power door lock won't
Lock and unlock both run off the same power supply...I'd be looking for a bad switch or a broken wire in the door harness where the wires go through the rubber boot between the door and pillar.
Alexander
vince
