Two very good answers, if you go to use the 50:1 ratio you will probably not be wrong most new stuff mixes with the 50:1 ratio these days if your not comfortable mixing the gas, Menards has premixed can for sale, as do most of the big box stores. Very good for novice mixers who don't want to keep alot of fuel around and let it go bad. Great alternative to mixing!
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
SOURCE: need oil/gas ratio for Echo back pack lblower -
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
SOURCE: SIR. I HAVE A ECHO
You can't go wrong with 25:1. Common accepted best ratio for this item to give best life for the internal components.
SOURCE: not getting fire to plug,replaced
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
