Televison & Video Logo
A
Anonymous Posted on Jun 21, 2014
What is the code to program the direct tv remote for model LN37B550
Samsung tv modelLN37B550
Mister Danger
Level 3:
  • Samsung Master 5,631 Answers
  • Posted on Jul 04, 2015
Mister Danger
Samsung Master
Level 3:
Answers
5631
Questions
0
Helped
1197695
Points
47629
You should look up in DirecTV control's user's manual. To get the manual, you should provide make and model of your DirecTV remote
DIRECTV Remote Control Code Lookup
5 Related Answers
Anonymous
  • Posted on Nov 27, 2008
SOURCE: remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Anonymous
  • 934 Answers
  • Posted on Dec 04, 2008
SOURCE: program remote for direct tv receiver
Not a problem - here's a site that was built just for that problem. http://www.remotecodelist.com/remotes/
Simply scroll down through the list of remotes and locate the remote. Then click on the link to find a host of codes and procedures to program that remote for almost any device it's capable of operating.
Hope this helps!
Bill
Anonymous
  • Posted on Aug 28, 2009
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Puppet03
Puppet03
  • 172 Answers
  • Posted on Oct 24, 2009
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
3764alan
Alan Spicer
  • 127 Answers
  • Posted on Nov 22, 2009
SOURCE: how do you program my tv(samsung) with universal
Read the instructions that come with the Radio Shack remote control. Or give a model number. Chances are you can find that remote controls manual online by searching google.com or such.
Testimonial: "thank you."
In need of remote code for samsung la40c650l1mxrd tv
Here are some general steps you can try to program your remote control: Determine the brand and model of your remote control. This information should be available in the user manual or on the manufacturer's website. Turn on your Samsung TV. Press and hold the "Code Search" button on your remote control until the indicator light turns on. Press the "TV" button on your remote control. Enter the code for your Samsung TV. You can find a list of remote control codes in the user manual or on the manufacturer's website. Alternatively, you can try entering codes until you find one that works. Press the "Power" button on your remote control. If the TV turns off, the code has been programmed successfully. If the TV does not turn off, repeat steps 3-5 with a different code. If none of the codes work, it is possible that your remote control is not compatible with your Samsung TV. In this case, you may need to purchase a new remote control or contact Samsung customer support for further assistance.
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
2answers
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
1helpful
2answers
I purchased a Westinghouse 32"
http://westinghousedigital.com/wordpress/wp-content/uploads/2010/05/Remote-Codes.pdf
That should give you the codes you need. Hope it helps.
I have a LG TV Universal remote and I'm trying to program it to a Samsung DVD/VCR Combo and I'm not able to do this. The remote model # is MKJ32022834.
TV manual has instruction and codes, or Check www.remotecentral.com for the manual and codes. Some combo setups won't work with alot of the universal remotes tha come with TV's. Also Try aftermarket universal remote.
3helpful
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
2answers
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
