Hotpoint TDC32 Electric Dryer Logo
A
Anonymous Posted on Jun 21, 2014
Dryer does not run when turned on - Hotpoint TDC32 Electric Dryer
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 • Dryers
My dryer turns on and runs for only a minute. It then turns off and will not turn back on. It is like there is an element that gets too hot when turned turned on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dryer won't turn on..says its on but won't run
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
1helpful
Dryer will not stay running. turns on briefly then shuts off
heatman101
Dryer drum will not run. When I turn the timer dial and hit start, the timer will run until the cycle completes but the drum nver turns.
heatman101
Dryer runs but the tub does not turn
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
When dryer is started it runs for a few seconds and turns off.
Dryer Repair ? The dryer will not start
heatman101
Drum turns when dryers not running
Does the drum just constantly turn and never stops or does it just take a really long time to stop? If it just takes a long time to stop it sounds like a loose belt. If it just turns and turns and turns something in the control panel isn't telling the motor shut off but with the clunking sound you're hearing I'd guess its the belt.
1helpful
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
1helpful
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
