OK, first off charge your battery and try again. Probably won't do anything but low power does cause problems. Second, check to make sure the mirror isn't stuck on its stop. If it doesn't move up and down freely, there may be a problem with the mirror. Finally, usual cause is motor failure in the aperture unit or shutter failure. If you can lift the mirror, lift it gently and make sure the shutter blades are laying flat. Unfortunately Nikon stopped selling parts over a year ago so you would have to send it to Nikon.
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Initialization Error/Press Shutter Release Again
Sounds like some software error.
Try updating the firmware for your Nikon D40 camera.
Here it is:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=14167&p_created=1169491133&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0zOjImcF9yb3dfY250PTEwODUmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x&p_li=&p_topview=1
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
SOURCE: D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
