What is an f8 eror code mean? We had a power surge now the oven don,t work at all but the burners do?
First, clear the error by unplugging the range (or turning off the circuit breaker) for 15-30 minutes. For ranges manufactured by GE, the F8 code indicates that the incorrect voltage is being seen at the electronic oven control board (EOC or clock). If the error after cycling the power, you need to replace the electronic control board. For Maytag ranges, the F8 indicates a problem with the electronic relay board. Again the part has to be replaced if the error persists.
Please add a comment with the model number of the range for information on the part number and pricing for the control board, if it is available. I hope this helps.
