https://www.instructables.com/...remove...seats/.../Identify-and-...
InstructablesNext slide both seat forward as far as they can go, and lean the back of the seat forward as well. Find the two bolt covers and remove them as well.
? 15:30 www.youtube.com/watch?v=qCLx3Ak2BvY Jul 31, 2013 - Uploaded by TheTongMan
Here is a tutorial on how to remove the front passenger seat and the rear ... what pieces of equipment are you ...
Hi, follow the instruction below...... Rear See Figures 3, 4, 5 and 6
Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
Remove rear seat back by tilting forward and pulling straight up.
To install:
Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks
1998 Villager Workshop Manual
REMOVAL AND INSTALLATION
Seat, Rear
Bench Removal
Remove the center seat(s) if equipped. Refer to the procedure in this section.
Slide the bench seat forward to the center row seating position.
Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
Remove the bench seat from the vehicle through the body side door opening.
