The maxium speed limit used to be displayed on the screen but after down loading updates it has disappeared...help!
SOURCE: Tom Tom 920
Your Favorites are located in the Map directory in the TomTom.
For example if your using the North American map (North_America).
In a file named MapSettings.cfg.
When you update the map and some times the application this file is overwritten.
I recommend copying the file to the root directory of the TomTom or your computer if changes are made. That way you have a easy back-up of your favorites file.
Unfortunately to recover your old file you may damage other file in the process.
I hope this helps.
Steve
SOURCE: cant use usa/canada map on tom tom 130 right out of the box
You have the option of unchecking items you don't want installed and updated every time you connect to TomTom Home. Reset the entire unit and update again to fix the error
SOURCE: tom tom one won't down load home automatically
First BACKUP your SD card.
Go here and download latest version of TomTom HOME >> For the PC or for the MAC , You can download tomtom HOME here >
http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=7408&p_created=1184659653&p_sid=PmvpQQmj&prod_lvl1=&prod_lvl2=&cat_lvl1=&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE1LDIxNSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZG93bmxvYWQgaG9tZQ**&p_li=&p_topview=1
I would recommend you only do a map upgrade if you definatly need to as looking at other posts on this forum lots of people have problems after trying to update maps.
Updating maps is NOT FREE , you have to pay for updates and after downloading updates you need to reactivate the map with your product code . Only do an update after backing up your existing maps other sie you might have trouble reverting back if the download goes wrong.
GOOD LUCK
SOURCE: just purchased tomtom v3 Great
i lost my activation code for tomtom v3 device code is AKWAC BAFQW
SOURCE: Every time I update my Tom Tom One XL, my favourites disappear
I have the OneXL Same Problem what about saving the favorites to the computer to restore after an update ?
