Question about Pride Revo 4 Wheel Scooter
How do you takshroud off the motor of pride revo?
    Habit-Forming:
    New Friend:
  • 88 Answers
You are almost certainly going to have to lift the seat off its post as you do with other Pride scooters. This is not light and it can be sticky and need tobe wiggled off - get help.
The shroud is usually velcroed into place and can easily be detached. Lift it off and put safely to one side.
Posted on Jun 02, 2016
4 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: Need Wiring chart for Revo 4 Pride Mobility
I have wiring chartfor Revo if your interested
Posted on Nov 09, 2009
gewiz
  • 1367 Answers
SOURCE: need wirirng diagram for batteries, pride revo
hi,
look at page 25, it contains a basic layout for the batteries.
http://www.pridemobility.co.uk/docs/UK_Revo_om.pdf
Please vote if this helps.
Regards
GeWiz.
Posted on Jan 06, 2010
  • 63 Answers
SOURCE: revo pride 2 year old
Well I hope I can be of Some help, If the batterys on a scooter are not charged daily after use they will deplete, in other words loss there power/charge.so each time you miss a charge the batteries will start lossing there life expectancy.that is why it Is very important to not miss a charge.When your batteries dont take a charge, that's basically saying you need new batterie. One way to make sure Your batteries need change and not your charger .... First trickle charge the batteries Second install the batteries back on the scooter Third plug in your charger it should kick on Good luck
Posted on Feb 11, 2011
NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Jun 11, 2012 | Pride Revo 4 Wheel Scooter
MY PRIDE REVO MOBILITY SCOOTER IS 3 YEARS OLD AND IS STARTING TO HAVE A INTERMITTENT FAULT OF GOING SLOW AND THEN FAST LIKE HAVE DIRTY PETROL IN A CARBURETTER IN A CAR
I know what the problem is as I have had it no less than 3 times with my own Revo. The Throttle Pot needs replacing. Luckily they aren't very expensive and you can fit it yourself if you are a handy sort of person. It just involves turning a screw to take out the old one and put in a new one. You can find diagrams on how to do it on the Internet. If you call a mobility company to come out and do it for you, they usually charge about £50 as a Call Out Fee.
The Revos seem prone to this throttle pot problem. Hope you get it fixed soon.
May 13, 2011 | Pride Mobility Products Revo (3wheel)
Sticking in and out of gear
Hi. When you say in and out of gear, does it free-wheel or just not drive? The jerking could be caused by faulty motor brushes. Fitting new brushes or getting the motor overhauled would probably fix this.
If you gave a better description of the fault, we might be able to give you a better solution. good luck. Neil.
Feb 10, 2010 | Pride Value Line Revo Scooter 3 Wheel
Need wirirng diagram for batteries, pride revo
hi,
Regards
GeWiz.
Jan 05, 2010 | Pride Mobility Revo 3 Wheel Electric...
Need Wiring chart for Revo 4 Pride Mobility Scooter
Nov 08, 2009 | Pride Revo 4 Wheel Scooter
Do all new Revo scooters come with newer low
SORRY,BUT THEY CAN'T BE CHANGED BUT ON UP SIDE THESE R SMOOTHER
Jul 15, 2009 | Pride Value Line Revo Scooter 3 Wheel
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
My Revo scooter will not move.It's like it's froze.The battery is charged. I turn it on and sounds like it wants to go but won't.
Sounds like the brake froze up on you.  It's the part that is attached to the motor with a handle on it to switch free-wheel and drive mode.  Try spraying some WD-40 into it and flip the handle up and down a few times then give it a go.
Apr 07, 2009 | Pride Value Line Revo Scooter 3 Wheel
Pride Revo 4 Wheel Scooter Logo
44 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
