General Electric WCVH6800J Front Load Washer Logo
Shannon Hoch Posted on Jun 21, 2014
My ge dryer basket is knocking - General Electric WCVH6800J Front Load Washer
GE dryer model # GFD14ESSNOWW, replaced door switch and board. Still has door fault. What next?
  1. User manual GE® GFD14ESSNWW Dryer ' manualsFile https://manualsfile.com/product/5i1x17x3f.html
    GE - General Electric GFD14ESSNWW ' File type: PDF ' Filename: GE® GFD14ESSNWW 24" 4.3 Cu.Ft. Front Load Vented Electric Dryer with Stainless Steel Basket.pdf ' Size: 3.68 MB ' Language: English, French, Spanish ' Other documents: 1 files. Download User Manual.
Jun 03, 2021 • GE Dryers
GE WCVH6260Fww knocks during spin
Had the same GE model number and similar problem. The basket (stainless steel) doesn't look centered in the unit anymore, you can tell when looking around the perimeter of the basket and compare to the rubber gasket. On front load washers the basket (the stainless piece that spins), if the door is open and if you push up on the basket there should be very very little to NO play or give . Meaning the basket should not be able to move up, down, side to side (not talking about spinning, just north, south, east, west). If there is play or movement there is a very good chance (thinking 95% sure) that it is the bearing. Not good news for any front washer but GE in all it's wisdom set it's crack engineers out to design this unit so that the bearing is not an individual part, this design has the basket (THE ACTUAL STAINLESS BASKET), THE SUPPORT ROD AND BEARINGS AS A SINGLE PIECE. The "Basket Assembly" alone is between $550 and $650, before tax, before labor if you don't do it yourself. If you decided to tackle this yourself you have to totally disassemble the entire unit to replace it. No exaggeration, you literally have to take the entire outer tub assembly apart to replace. If you are able to accomplish this without damaging any other part then you have to Humpty Dumpty back together again, without damaging anything else. Hope this helps.
1helpful
On my washer/dryer stacked combo, the dryer has a new rubbing sound when the inside basket turns. It may feel as if the basket has fallen a little but I never checked it before so it may be sitting...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
3helpful
Ge gas dryer every revolution there is noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
heatman101
ghgf
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Deep Fryer Handle
Go to "Appliance Parts Pro's" web-site if they dont have it they will find it and prices are reasonable and shipping is fast
1helpful
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
GE Electric Dryer DBXR463EG0WW making loud griding noise when on
heatman101
Clicking noise
heatman101
vbmvc
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
