Question about Frigidaire Refrigerators
How can I fix my fridgidaire refrigerator model #frs26h58sb4 leaky water dispenser.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Scott,
I understand you are trying to repair the leaky water dispenser on your Frigidaire refrigerator, model# FRS26H58SB4. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Posted on Jun 23, 2014
SOURCE:
  • 5 Answers
SOURCE: Fridgidaire refrigerator freezing
close the baffle that blows air onto the top shelf a bit.
Or you have a bad thermostat or thermistor- if it's a didital type temp cuicuit
Posted on Oct 26, 2007
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
  • 401 Answers
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 12, 2010
What is causing the water dispenser to drip? Ice is making fine
most likely a leaky water inlet valve or clogged dispenser defrost pipe or water tank leaking or water filter leaking.
Aug 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
Good Morning Friend,
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Refrigerators
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Fridgidaire refrigerater dispenses water
The part number you are going to need is 241734302. This is the water valve located in the back of the machine. Whats going on is the solenoid for the dispenser isn't seating properly and when the icemaker calls for water the pressure is enough to push through and come out the door as well
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 24, 2012 | Refrigerators
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaky water dispenser. How to fix
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Dec 15, 2009 | Amana Refrigerators
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice smells, and tastes bad...no filter to change?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have water in the dispenser but the ice maker doesn't fill
replace the solelnoid for the water dispenser in the back of the fridge
Oct 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
