Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
3 Ports on the side- Pink,Green,Black Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop. b) Go to Control Panel and open - RealTek HD Audio manager On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic, The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or you might have to depending on your operating system Click start Control Pannel Click on Hardware and Sound
Click on Sound then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in then select headphones
at the bottom it will say set as default select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enablewindows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click selectconfigure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphonethen next and next againyou should see your earphones with microphone being configured click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
sony trinitron is a very old model CRT television and will most likely not have even the red/white/yellow jacks. It will have an antenna jack, and a earphone socket.
The model laptop that you are talking about has a bad graphics card which is part of the motherboard. It is an Nvida product that over heats and fails.
If you go to HP's website forum and searching for "black screen on start up" you'll see a lot of messages.
I have an HP dv2025nr same issue. HP will replace motherboard for around $400.00
