Hey;
Changing password on a router is quite simple. Depending on which router you have, the factory login and password might differ.
First you have to log into your router. use
http://192.168.1.1
Then you will be prompted for user id and password
login: admin
password: admin
or password
if you are using a verizon router, use
login: verizon
password: password or password1 (when you type the password it will show multiple dots for each character)
if your router has a different password already pre-set then you will have to reset your router. This will change your network name and reset the password to factory setting, like above.
Locate the reset button in the back of the router. While the router is turned on, press the reset button for 10 to 15 seconds and release. The router should now reset. Once it resets, just fallow the steps above. You may also click on the "Wireless" tab and change your network name as well.
Hope this helps.
