I can't find driver for windows 7. I find only for XP
SOURCE: Creative Live! Cam Voice not detected by software
i got that camera but i loss software so where i acn get software for live cam voice
SOURCE: Creative Live! Cam Notebook Ultra Driver for windows 2000
The best wouldbe for you to write to Creative it self. some time in win 200 some featre might not ork properly. any way try sending a email to [email protected] this is the asia support address. they are very prompt. hope you will find your driver.
SOURCE: Windows 7 does not recognize the Web Cam
instal Picasa 3, it recognizes all web cam without any driver
SOURCE: I cannot unistall driver for Live! cam voice. I
start it in safe mode turn off your firewall and turn off your antivirus go to add and remove programs remove all web cam or creative drivers that you see then close out add and remove drivers and go to device drivers click on start my computer right click on my computer go to properties and click on properties go to hardware and remove any web cam devices in the list of hardware then close out the window. next go to start type in the run box msconfig go to start up files and go down the list and if you see any drivers or load up devices that has to do with creative drivers unchecked them also check ini flies and uncheck them then click apply and OK and reboot. next go back into safe mode it will ask you if you want to reboot say no next do disk clean up then disk defrag next click restart and go to the regular screen it will say your in diagnostic start up do you want to continue or reboot continue. next be sure camera is not hooked up and check your hardware device to see if you see a web camera if you do remove it by clicking on it and remove driver, now close out the window and now install the CD for the camera install the software with the virus software and firewall off after installing the software and it reboots go to where it says you are in diagnostic mode and click on it and click on apply all then OK and allow it to boot, next hook your camera into the computer and let me know if that works if not I will try to think of an easier way. Thanks for using fix-ya.
SOURCE: DRIVER FOR WINDOWS 7-WEB-CAM
go to folowing link your get all solution for web cam
http://support.creative.com/kb/showarticle.aspx?sid=61105
Requirements:
