SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
SOURCE: lg tv modle DU-37LZ30 on off indicator light is
Most likely a power supply problem. I recommend taking this to a certified technician and having them look at it.
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
SOURCE: RZ-42PY10X LG TV I HAVE A RED LINE DOWN THE RIGHT
Hi
Thanks for using FixYa. From what
you have described it seems that you
might have a backlight issue with this TV set. It could also be due to the
inverter circuits for the backlights. The inverter is the power
supply source for the backlights. There could also be a screen driver
problem; if it is then you have to change the entire board. All this is only
recommended if you have some kind of expertise for checking the internal
circuitry of the TV as these units have high voltages running even when the set
is switched off. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
Testimonial: "is there any chance i could get hold of the wiring diagram"
SOURCE: I have an LG plasma model# DU-42PY10X that seems
This is a common problem on these sets. As the menu is fine, this is highly suggestive of an internal failure.you have a driver board failing if you would open the set and on the
left side is the Y-sustain board there are two boards connected to the Y
SUS board. The one on the top drives the top half of the picture and
the one on the bottom drives the lower half of the picture open the
ribbon cables make sure to clean it or Re solder if you see needed turn
set on and test, sometimes cleaning this will fix problem sometimes re
soldering will fix problem and last resort is, the board itself is bad.Unfortunately,you need to diagnose and inspect all the components before replacing any part.If you wish to repair it yourself, i could give you a link to buy the service manual and would upload a troubleshooting chart ( generic ) that would explain how you need to diagnose the fault when you open the TV.However, there is no quick fix. It has to be opened and tested and then diagnosed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
