Call Sportsmith #800-713-2880.Make sure you have the serial # which you find it on the side of the machine. The will help you.
There a few possible options for the battery. This link will take you to all of them. Please have your serial number ready to help narrow your choices.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: efx 546 in diagnostics mode,
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
