Garden Logo
A
Anonymous Posted on Jun 20, 2014
No pressure runs fine but no pressure
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Feb 06, 2019
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
384907
Points
2343
Possibly pump froze during winter and damaged.
Have a 2005 f150 4.6 that stalls can it be the fuel pump is weak
Could be a fuel pressure regulator not working. Thus ecu complaining about fuel Pressure. probably not enough because the regulator is worn and leaking down so will not maintain the proper pressure. You will need to google the make model and fuel pressure regulator to find it's location or library and repair manual. Otherwise, you need to measure the pressure and find the spec for the required fuel pressure. Probably somewhere around 120PSI
Grand am 3 4
Sounds like a faulty fuel pressure regulator, or possibly the MAF sensor.
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oil pressure light comes on and says that the oil pressure has dropped. but the truck is running fine
You could change the oil pressure sending unit to see if it is faulty, or have the oil pressure checked with a mechanical gauge.
Honda pressure washer, no pressure
sounds like you have a stuck pressure release valve inside the pump
Jun 23, 2012 • Garden
My Peugeot 206 HDi (not listed to pick) runs fine until eng temp reaches 80 then suddenly becomes very lumpy. If I need to accelerate there is no problem and it runs fine but as soon as I ease off on the...
Please Check High pressure fuel pump. In my opinion your fuel pump connected to timing belt is giving away. When you increase rev on engine, the pressure increases as well. As a result, Injector spray pattern gets steady. But on revs below 900rpm it struggle to maintains required pressure. If everything in fuel injection system is working fine then the Worst case scenario is that the head pressure is leaking aka compression leakage.
2helpful
Car ships replaced wires plugs o2 sencer sometimes acts like it is flooding run fine on open road.
If it acts like it is flooding while idling, but it runs fine on the road, it could be running too rich and flooding it out due to leaking injectors, bad fuel pressure regulator, or excessive fuel pressure.
I would start by replacing the Fuel Pressure Regulator since it doesn't cost as much as the injectors.
Check your fuel pressure using a Fuel Pressure Check Gauge to see if the fuel pressure regulator is maintaining the proper pressure.
Vacuum is attached to the Fuel Pressure Regulator to control system pressure. When the fuel pressure regulator is not functioning properly it causes the fuel pressure to be above normal operating pressure. This condition causes excess fuel to be injected causing a rich mixture that produces black smoke.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
1helpful
Motor runs fine but not pressure other that from garden hose.
you have a unloader or bypass valve on the machine & it sounds like that is sticking.
take out and lubricate
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
