Nikon N60 35mm SLR Camera Logo
A
Anonymous Posted on Jun 20, 2014
My door won't stay latched- can it be fixed? - Nikon N60 35mm SLR Camera
Art Schneider
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 31, 2014
Art Schneider
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
480
Points
5
Yes, I have installed hundreds of these latches (I make metal replacements)! Not sure if I am allowed to post my web site on here but I'll try! www.flcamerarepair.com. email: [email protected]
Door wont latch
FIX CAR DOOR LATCH - YouTube
? 1:29
https://www.youtube.com/watch?v=wmWsM-TSaKo
Oct 21, 2011 - Uploaded by benherrerajr
Ever had a car door that wouldn't close? If the latch was accidentally stuck down, then here's the most ...
DIY Fix & Repair For Car Doors That Will Not Close
finley.xyz/diy-fix-repair-for-car-doors-that-will-not-close/
You are out and about and your car door suddenly won't close and stay shut. ... should be your first go to choice for repairing a car, truck or vehicle door latch of ...
Car Door Won't Close or Stay Shut - JamesMaurer.com
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Dome light and key in ignition tone won't quit.
Yes, I would lean toward a stuck drivers door latch. Your door open switch is located in the latch itself and the ding is a reminder your key is in the ignition so you don't lock them in the vehicle when you lock the door. even though your door is shut, the truck still thinks it is open. sometimes spraying the latch with some WD-40 will get it freed up and working again, but a new latch might be in your future.
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Door on 95 geo metro 4 door won't close because the child proof lock in on and I can't get it to go off. Door won't stay shut. Any ideas how to fix this?
Your childproof lock have nothing to do with the latch not closing. It only makes it where you can not open the door from the inside. I would think you are in need of a new latch.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
