Question edited to add full make model (what it is).
Question moved from 'Health and Beauty' Category.
Sounds like either the charger isn't providing power at the connector, despite the green light, or that there is a battery fault. Contact the maker in Warranty Returns or start testing with a multimeter.
??????????4 out of 5 stars.· 2 years ago Great but......Back brake pads worn out within first 6 months as well as the battery. Second battery only lasted 4 months . HORRIBLE.. warranty I believe is like 30 days. Hard to replace battery. Literally have to take apart whole middle section of bike to remove it. Parts are extremely high in price.
Clutch disc facing material may have come apart, causing clutch to drag when it should freewheel. Disc replacement may be the only cure. This can also cause vibration because disc is now unbalanced.
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
WOW!!!WHAT A JOKE!MY KID SAVED $470 AND PURCHASED HIS MX 650 ONLY TO HAVE THE REAR FREEWHEEL BREAK THE FIRST WEEK RIDING IT.NND BY SEEING ALOT OF THE SAME PROBLEMWITH EVERYONE ELSE.RAZOR SHOULD' VE AT LEAST PUT A HEAVYDUTY ONE IN IT.OK PEOPLE LETS FIGURE IT OUT IF ANY ONE KNOWS AGOOD BEARING COMPANY,POST IT.MY KIDS BUMMED HE CANT RIDE IT
Did you lube your clutch actuator. Don't know if actuator is going to be the name used in "the book" but this is the part that the clutch cable hooks to at the engine. Normally clean it and lube it with a little grease and that'll free up a clutch nicely
