SOURCE: Traxxas tq controller has steering
Towards the bottom of the controller there should be two small switches. One switch will be for the steering servo and one for the esc. Channel 1 should be for the steering servo, move that switch and that should correct your problem.
SOURCE: vehicle running slow with a full charged battery
Have you tried a different battery pack? Also check slipper clutch and motor. The slipper clutch could have backed off. The motor could have brushes that need replace or bearings that need oiled.
SOURCE: traxxas rustler electronics arent working when i
take the esc apart buy the four screws on the bottom if it smells like bad electronics your screwed
SOURCE: my rustler traxxas rc truck
it is your motor titan 12 t it is burnt out I had the same problem just replace the motor and your golden
SOURCE: using lipo s it goes to low voltage shut off
the packs may need to be balanced..most good chargers have an option to balance your packs out..one cell may be stronger so it is running off that cell then acting dead
