For the third time we have had a repairman out to re-connect rubbed exposed wires inside the 2.5 yr old oven. What can I do?
Good Afternoon Friend,
I understand you are having electrical problems with your Frigidaire double oven, model# GLEB30T8A. I also see that this is the third time you have had a repairman out to reconnect exposed wires in your 2 and a half year old appliance. I suggest contacting the manufacturer directly. They might have some advice or might be able to point you in the right direction to having your double oven repaired for good. Hope this is helpful.
-Best Regards-
WP
SOURCE: oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
SOURCE: lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
