Hello sir When i swith on the printer it showing initializing please help me to solve this problem
SOURCE: standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
