1. On the handset, press menu/select button and select (with arrow key) Answering Setup and then Record Greeting.
2. Press menu/select button to start recording and, after system says "record greeting", begin speaking.
3. Press menu/select button to stop recording.
Follow the instructions beginning on page 43 of the manual: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580om.pdf
SOURCE: How do I re-record my
If you're talking about the answering machine greeting in the base unit, detailed instructions are here: http://www.uniden.com/pdf/DECT1580om.pdf
If you're talking about the voicemail system provided by your local telephone company, each will be different, but my ATT UVerse voicemail is controlled at http://www.att.com/uversecentral and then click My Account, My Services, U-verse Voice Home Page. Hopefully ATT doesn't shuffle around the menus by the time you read this. This is correct as of Dec 2010.
-Andy
Recording a Personal Greeting
Press /mute on the handset. The system announces the number of new and old
messages, and then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback.
You will hear intermittent beeps indicating that the system
is in the command-waiting mode.
Press 8 to start the recording.
The system announces, "Record greeting."
Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You
will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone
automatically switches to your personal greeting. You can also switch back and
forth between the pre-recorded greeting and your own greeting at any time.
Press /mute.
The system announces the number of new and old messages, and
is in the command waiting mode.
Press 6. The system plays the current greeting.
