SOURCE: How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
SOURCE: two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
SOURCE: E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
SOURCE: no electrical outlet available for the base station (wall mounted)
AFAIK there is no answering machine that will work without being connected to an electrical outlet, neither will the caller ID. The corded handset on the base unit will work, but that is it. The base uses the AC power to transmit and receive to/from the cordless so you won't be able to use the cordless handset with out the base being connected to AC.
SOURCE: I have a Uniden 6.0 DECT Digital Answering System,
unniden has manuals on their website in PDF
