Kenwood KM800 Major Classic Stand Mixer Logo
Posted on Nov 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Beaters fall down
Beater falls down when i start to mix.
have ent mixer back to factory while still under warranty
but to no avail I don't even think the mixer was even looked at.
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Jul 11, 2008
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
53109
Points
146
Mirran`s sollution is correct
Anonymous
Level 2:
  • Expert 515 Answers
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
245810
Points
948
You have to change the planet hub and the beater.
  • iAN pLATFORD Jul 13, 2013
    I have the same problemwith a KM005. Apparently the planet hub has been modified and so does not fit without some modification to the est of the macheine. Can you tell me what other parts i would need please? The serial number for my machine is 0059104.
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
1helpful
KP26M1XMR beater shaft falls off
The beater shaft on the 6 quart mixers is part of the planetary assembly. The planetary and center shaft are pressed together, and sometimes they will come apart. The only way to fix this is to replace the planetary or you can have the planetary machine pressed back together.
It is a lot cheaper and less expensive to just replace the planetary. Here is a link to the Planetary Assembly on our website. http://www.mendingshed.com/9708662.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
2answers
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
KitchenAid model KB26G1XGN. The planetary gear appears to be falling out. The mixer blades were hitting the bowl before I had the bowl in the locked position. I got the top of the gear box off but can't...
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
See second comment...
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 12, 2009 • Food Mixers
5helpful
Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
3helpful
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
2helpful
2answers
KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
