The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
SOURCE: Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
SOURCE: I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
SOURCE: Husqvarna 450 e-series 18" Chain Saw will not
Is this machine mechanically sound, remove the muffler and take a look at the piston through the open exhaust port, any signs of scuffinf or damage to the piston skirt and the saw will have to come apart for further investigation.
