Question about Jugs Small Ball Pitching Machine
Power shuts off when i turn on switch - Jugs Small Ball Pitching Machine
  • Steve Manookian
    Steve Manookian May 03, 2015
    It is a simple on off switch. If the machine works good, Maybe just the switch label is backwards
    New Friend:
  • 27 Answers
Also, could be a dead short or short to ground causing the breaker to trip or it could be a high resistance short.
Look at the Amps required to run the machine. Most household circuits are 15-20 amp and most household outlets are 25 amp.
Posted on May 03, 2015
    New Friend:
  • 7 Answers
There can be two possible reasons for this to occur. The first would be that the pitching machine might need more power than that which is available at home, or the machine might be working for a long time and may have got heated up.
Posted on Jan 30, 2015
SOURCE:
Vacuum works but won't shut off
Switch is broken in the "ON" position. Just plug it into a power strip outlet and use the switch on the power strip outlet to turn it on and off.
Nov 08, 2015 | Vacuums
My Kindle Fire HD won't turn off. I was watching a movie on Netflix and the picture just froze
Turning Off the Kindle
Quickly sliding the power switch on the Kindle enters and resumes sleep mode. If your Kindle enters a non-responsive state when sliding the power switch, you've likely entered sleep mode. Try sliding the power switch and holding it for four seconds to shut down the device. If it still does not shut off, you may need to reset the Kindle.
Resetting the Kindle
The power switch also serves to reset the device. Before resetting the device, disconnect it from any power sources, such as an AC outlet or your computer's USB connection. Sliding the power switch and holding it for 20 seconds forces the Kindle to reset and power down. However, a nearly depleted battery may prevent this action. If the Kindle still doesn't shut off, try charging it for several hours and resetting it again.
Mar 17, 2015 | Amazon Kindle Fire HD 8.9"
Car will not shut off
It won't shut off because even with the switch in off position there's still power from the alternator going to your firing system because a wire has crossed, possibly from heat and melted together at the alternator, and is keeping power from the alternator feeding the wire going to the switch. Start the engine, unplug the alternator, then shut the switch off. You'll see what I mean when the engine dies because the alternator is unplugged and switch is turned off. No problem. Fix the wires.
Oct 12, 2014 | 1993 Ford Tempo
Why does it fire when the key is shut off
Ignition switch,bad fusible links, coil,ignition module. I have replaced several switches for this problem. At the coil, when you turn the switch on, there should be power. There also should be power when trying to start the engine. If there is no power while cranking, replace the switch. The reason it hits a cylinder or two is that the power goes to the coil, just not enough to get the engine running..
Aug 08, 2014 | 1981 Chevrolet Corvette
I have an Adcom GFA 555 type II that won't shut off when the power switch is turned off...I'm assuming a relay problem?
please replace power switch to solve amplifier problem as power switch internal contacts seems stuck and does not disengage to turn power Off.
Thanks.
Mar 19, 2011 | Adcom GFA555 Amplifier
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
2006 tahoe with heated seats. when the seat is
The heating element in the seat may be failing, even thogh it heats the seat, the element could be causing the circut to spike upon power shut down. Relay takes mili-second to shut down after ignition kill and power feed comes direct from battery. Check amp. draw at switch of bad seat and good seat upon shut down. If bad seat higher that 5 amp difference element n/g. Also check for bad relay as they can short internal and cause problems if primary power cut before switch shut down.
Jan 30, 2010 | 2003 GMC Sierra 1500
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Emachine not turning off.
you can checkit by unhooking it on the inside from the mobo panal just remember where it ogoes back take a small flat head and cross the two prongs it comes of off then shut it down if it works look on ebay for a complete front panel with switch or order from emachines.
Oct 29, 2008 | E-Machines eMachines Desktop PC
No fuel
I come to find out,the fuel command is controlled by the computer, due to corrosion in the internals, it is not telling the fuel pump to turn on,so in turn, I run a switch to the power side of the fuell pump, it works, but the weird thing is, you only need the power on to start the truck, after its running, you can shut the switch off, it stays running, shut it off, you need to turn the power on to make it start pumping again, now who can explain this??
Jun 22, 2008 | 1991 Suzuki Sidekick
Jugs Small Ball Pitching Machine Logo
1,173 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
