Instructions for lighting the unit are located on front of water heater. Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc. http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances. Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
Gas water heaters don't have elements, so I am confused about what type water heater you have.. Look on the side of tank for the label. Find the brand, and type. Does it show BTUs? Or does it show wattage? Then re-post question with this information, for best possible answer. Also post question on Tank forum. http://www.thetankatwaterheaterrescue.com/forums/forum3/
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not?? If it is blinking then the pilot should stay lit... If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
The manual says to hold a match near the pilot while the ignitor is
trying. It says that if the unit lights the pilot orifice may be dirty
or clogged. Then the manual says to check
the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
