What would cause the oven door is to lock and keep the burners from turning on?
Good Afternoon Friend,
I understand that the oven door is locked and you are unable to turn the burners on for your Frigidaire range, model# FEF365AS. It sounds like your range could possibly be in a "Lockout" mode. Please try pressing and holding down the "Clear/Off" button for 3-5 seconds. This should unlock your oven as well as allow you to use your cooktop area. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
SOURCE: Cooktop Locked Up!!
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
SOURCE: Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
SOURCE: Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
PT NO 3148558 Kenmore
Why do I have a blinking oven light on the clock panel?
