The batteries need to be replaced, or at least the most bad battery!Open cell in the battery.
You can't post conmments that contain an email address.
the manual covers this, it tells you to read alarm event code
messages they are not in number format but text.
in clear english the alarms.
RTM or call EATON, we are Fixya not EATON,ok>
most error common means bad batteries. 99% are.
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
