Refrigerators Logo
A
Anonymous Posted on Jun 19, 2014
Haier refrigerator freezer not working - Haier Refrigerators
5 Related Answers
mgprice
Mike Price
  • 744 Answers
  • Posted on Aug 15, 2009
SOURCE: Freezer Works Regrigerator Does Not Cool
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s please don't forget to rate my solution....Mike
Testimonial: "ty"
Anonymous
  • 24 Answers
  • Posted on Oct 29, 2008
SOURCE: HAIER HTE18WAA
The thermostat that controls when the compressor needs to run has probaly quit.
Anonymous
  • 110 Answers
  • Posted on Apr 12, 2010
SOURCE: new haier freezer with no refrigerant and no way
what you have to do is have your leak fixed and they make schrader valves that have to be installed so they can be recharged what i would do is stop and ask an ac man if he wants to make a few xtra bucks after work and how much is it going to cost ask one or more ac dudes youl find one
Anonymous
  • 43501 Answers
  • Posted on Jul 31, 2010
SOURCE: I have a 20.7 cubic feet Haier frost free
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Anonymous
  • 713 Answers
  • Posted on Feb 22, 2011
SOURCE: Haier Refrigerator RRTW18VABW Freezer works,
thermastate went bad in frig.
Hi I have a refrigerator Haier #HA10TG205S The fridge is not working, but the freezer is? HELP! it is only a couple of years old?
Check the adjustment arrow has not shifted on the theremostat, they also have a 36 mth warranty.
I have a Haier refrigerator model #rrtg18paaw and the freezer is not working but the fan is please help?
At this point I am assuming the refrigerator portion is working. It sounds like it may be a thermostat or a low refrigerant charge. If you cannot find it with the links I have attached you should contact a servace tec but also it possibly is in warrenty so start where you purchased the unit.
Haier10 11 cu ft Top Freezer Refrigerator White
20 7 Cu Ft Frost Free Top Freezer Refrigerator ENERGY STAR HT21TS45SW
Haier Refrigerator Parts
Haier Refrigerator Model RRTG18PAAW Parts
Haier refrigerator freezer not cold
feel the top of the compressor is it warm or is it clicking noise or is it hot can you tell me that?
Appliance 911 Sea Breeze
My haier hrf380h cooling in refrigerator has stopped .I think due to malfunctioning of solenoid .freezer is working 100 % accurate plz advice
selonoid? sounds more to me like ur cold control thermostat? or bad thermistor or thermistors, however a bad not working fan in freezer will stop air flow and do would a bad damper vent from freezer to fridge if its stuck in an open or close position
Refrigerator turns off restart a couple days later haier hnde03
the is an electronic timer for defrost mode on all frost free frig/ freezers it goes bad to find that in your frig call the manufacturer or a good repair man
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Top freezer is workiing fridge is not haier preference series htp 18 gaa
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
2helpful
My refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
HAIER HTE18WAA
1helpful
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
