Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
A
Anonymous Posted on Jun 19, 2014
Mower wont turnover at key switch
Was running just cut off wont turnover with key but can jump solinoid still wont start
Ted Mostert
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 20, 2014
Ted Mostert
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
10
Questions
Helped
2816
Points
16
Mower has multiple safety switches, seat,&hydraulics, also a bad PTO switch will cause them not to start.
John deere L20 tractor mower will not start. it wont even turnover. i think it has something to do with the pto kill switch
There probably several kill switched, on the PTO and another under the seat. For diagnostic purposes only the switches can be jumped with a wire to see which switch is bad. Once it is located remove it and replace it with a new one.
May 21, 2014 • Garden
Partstree.com
there is now power from the ignition switch to the sinal wire on the solenoid, may be a fuse, or a faulty ignition switch
2helpful
Yard king runs but ignition key to starter faulty, need to jump directly to starter
check the safety switch on the brake/clutch pedal bypass it with a paper clip to test it
May 09, 2012 • Garden
Engine wont crank or start from key but will crank running cables to starter
there is a safety switch under the mower the clutch pedal closes for starting
look for plug to be off or cut wires.
also the solinoid switch close to battery could be bad.
don't forget to rate me.
thanks.
Jul 07, 2011 • Garden
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
1helpful
I have a cub cadet zforce 48 zero turn. It wont start unless I jump across the solinoid. I've changed it and still does the same. Whats the problem?
Make sure the control arms are all the way out, the brake is locked in the on position. There are safety switches on each control arm and one on the brake lever, also there is a safety switch on the seat...if either is faulty the mower will not key start.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
