If it is a Windows Mobile 5 device, reload the OS in full using SD card method. If the device is Windows CE5, you can enter IPL mode by doing a coldboot, and whilst inserting the battery back in the device, press the trigger and put it in the cradle until it enters IPL. Once there, you can either use SD card with the OS Hex files or you can use USB Download from Motorola to download the files sing a cradle from your PC. It will be recognised by the PC as this method does not use Active sync.
SOURCE: Motorola MC9090 G oes not cold boot.
I'vefound this method works best especially on Window Mobile versions, windows CEdoes not seem to have the problem.
If it stillfails after this I would suggest a complete re-flash of the system. Please posta follow up question on how to do this.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
[email protected] orTEL 01202 620955
http://www.biastechnology.com/
SOURCE: Can I automatically enable radio and connect to my
Activate WLAN at coldboot on MC9190 with the following registry entry (.reg file)
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\WLAN]
"InitialState"=dword:00000000
Regards,
Frank Damman
SOURCE: Where is the MAC address located on the Motorola MC9190-G Hand held scanner
From the main screen, select the Wireless card >> Fusion Settings >> Wireless Status >> IP4 status. [email protected] or TEL +44(0)1202 620955 http://www.biastechnology.com/
This then shows you your mac address.
