Hire a Technician with a programmer to adjust the program for you.email me if you need help getting a technician
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
SOURCE: we have a problem with the joystick controller on
The joystick is a sealed unit. If there is a problem with the joystick then you have to replace the whole unit.
SOURCE: My jet 3 has been
Hixx the batteries are too low to light up the joystick and no amount of charging will bring them back. Sorry you will have to get new batteries. You will need 2 U1 batteries. Hope this helps
SOURCE: Hi i have a Jet
Good day,visit the manufacturer website & go from there.Alternatively,ebay is a trusted site to purchase parts also.Have a nice day,Colin.
