Frigidaire FRT21P5A Top Freezer Refrigerator Logo
Ellie Graham Posted on Jun 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my freezer not cold enough?
My freezer (Electrolux FRT21P5A) is not cooling enough. I vacuumed the coils which were very dusty but still not improvement over the past few days. The milk in the fridg still tastes good so I think the fridge part is working okay. I hear a motor going in the freezer. It is on the coldest setting. How can i fix this? Thanks!
Bob L
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 413 Answers
  • Posted on Jul 25, 2015
Bob L
Expert
Level 2:
Mentor:
Answers
413
Questions
Helped
75687
Points
735
I beileive that you are low on freon. Call service company and they can fix> Good Luck!
5 Related Answers
A
Anonymous
  • Posted on Oct 22, 2007
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
Anonymous
  • 1314 Answers
  • Posted on Mar 30, 2008
SOURCE: Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
A
Anonymous
  • Posted on Sep 26, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on Nov 25, 2008
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Jul 05, 2009
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Electrolux ETE 4200 SB-R freeze fridge. freezer cold, but fridge wont cool. back of the unit sealed with only compressor (?) visible at bottom. Cant check fans, coils etc. Cheers Gary
That is not a good model number. Is it a top mount freezer or side by side? Generally in electrolux the freezer is what cooks the fridge, if fridge is not cooling, it could be several things causing it.
1. Damper not opening
2. Damper has ice build up
3. The return has ice build up
4. The freezer evap assembly is not defrosting to allow air flow.
5. The evap fan is not turning.
Refrigerator with bottom freezer. Yesterday I noticed that the freezer was suddenly not cold enough... It's cold, but the ice cream is mushy, and the day before it had been hard. I'm certain the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Freezer is working but the bottom refrigerator is not cooling?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Freezer ok fridge not cooling
heatman101
wHGJ
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
GE Side By Side top portion of fridge and freezer not cooling
heatman101
3helpful
Appliance Outlet
Thanks,
Bill
The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Miele Fridge freezer - the freezer temperature indicator shows the temperature to drop from 20 to 10 in under one hour despite the door not being opened. By switching on the super freeze the temperature...
first...Check whether the ventilation gaps
have been covered over or become
dusty.
2. Check whether the metal grille (heat
exchanger) at the back of the
appliance has become too dusty.
It needs good area of circulation and clean coils/grilles.
it makes it hard to cool it down if dirty/dusty. I don't think the oven is doing it cuz operating in a room/outside which is too cold will cause the cooling system to switch
off for too long, causing the freezer
section to become too warm.
My best guess is vents and coils dirty/dusty.
2answers
Freezer stays cold, but not fridge
i had the same proble open freezer door and unscrew back plate if coils are iced up its eather a sensor on tot or the heaters lond tubes you can see if all iced up get blow dryer out to defrost
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
