First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
SOURCE: Nikon Coolpix 5600 can't upload to PC
I need to know the log appearing before I can assist. Many issues can cause cameras not to upload. Is this a sudden problem, ie, have you uploaded before successfully to your pc? Pc issues will also stop you. Let's do this step by step ans start with the log thta appears. Let me know.
SOURCE: When I plug the Nikon
i try to upload photos from my nikon coolpix p50 to 'my pictures' by using my usb cord. it always used to work but not now. something pops up that says "please make sure the device is turned on and properly connected to the computer." i used the the same usb cord as before when it worked.
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom. Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
SOURCE: my nikon coolpix s210 won't upload pictures on my
try going to my computer, then selecting under "devices with removable storage" the one that says coolpix, camara, something along those lines. mine says "nikon D40". double click on that (if it's there) and that should be it. mine doesnt autoplay either.
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
