My 2003 is not getting hot air i changed the heater hoses and put more antifreeze in and it still wont get hot air
One of two things: 1)Heater core may be plugged - on most vehicles you can switch the heater hoses around to reverse the flow of water to try to remove the blockage. This will be a temporary fix however because the foreign material will be in the coolant system and will eventually plug the core again. If you try this and it helps I would suggest flushing the coolant system to remove any loose material. 2)Failed water pump - Sometimes the impeller on the water pump gets corroded to the point where it will not move the coolant correctly. The solution for this is to change the pump. You can do some troubleshooting buy A)draining enough coolant from the system to drop the level below the upper of the two heater hoses B)remove the upper heater hose on the engine end and position the open end higher than the engine, allow coolant to drain to the point where it naturally stops C)Have a friend start the vehicle breifly and see if coolant flows from either the hose or the fittting it was connected to. If coolant flows from the hose, the core is not plugged. If coolant flows from the fitting, the water pump is working. If coolant doesn't flow at all, try switching the ends on the core if possible and repeat test. If the coolant still doesn't flow, you probably need a water pump.
