You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
What is the model number of your router? Bypass the router and connect the computer directly to the modem. Make sure that your computer is able to access the Internet through the modem. If the modem is working fine the connect the modem to the router and computer to the router. Reset the router for 30 seconds. Power cycle the router. open the setup page of the router using 192.168.1.1. Try to setup linksys router.
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
To setup the router you will need to log in to your router's control panel. This certainly won't be as simple as on the installer disc, yet it is still do-able. You might also want to contact Belkin's free technical support hot line. They can help you set it up with the method I described above.
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup. From wall jack to Westell modem, From modem to uplink port on Max G router. Reboot Westell modem. T Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
