Hi. I think you mean an SE-S300. You need to make sure you use 57mm thermal paper. It will have a shiny smooth side and a rough side if it is the correct paper. When you fit it into the printer, make sure the shiny side is facing you as it feeds out of the printer otherwise, it will feed out blank.
Fitting instructions are here:
https://www.youtube.com/watch?v=kDiOb43frPw
SOURCE: printer roll
* check the power outlet is fine
* check the connections you have made is properly connected or not
*see the power cord is fixed properly if properly fixed change the cord and see
*please put ur till roll at right place
thanks
SOURCE: i have a casio TE-100 cash register model 5610057
Program 2 mode (2 subtotal)
132 subtotal, type new name for first line, 00, cash, subtotal
for the other three lines, just do the same, but use 232,332,or 432 in place of 132
If you need more information, the Casio TE-100 manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-100_users_and_programming_manual.html
SOURCE: problem programming PLU s on casio SE-S2000
i got an error in my casio ses 2000. the error no is E008. i can't sign on
SOURCE: hi, i have a CASIO SE C2000. The ink is not
If it is feeding the paper but it is blank, then you may have the paper around the wrong way. the shiny side must be towards the front. Otherwise, it may not be thermal paper. If it is not feeding out at all, make sure it has not been turned off (paper saving)
