Question about Korg KROSS-61 61-Key Workstation Keyboard/Synthesizer -
How to access SD card on screen KORG/KOSS 61 music workstation
3 days ago, my Pastor purchased a KORG/KOSS 61 Music Worksstation. i have intrumental sounds on my Computer with WMA. how can load the SD Card with these songs so that i can just press play on 'NEW' keyboard..please help...my email: samoan562002@yahoo.com, my name is Tino..i gotta get this keyboard ready before Church this sunday...cell:9252038820 Thank You
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
2 Suggested Answers
SOURCE:
  • 298 Answers
SOURCE: i have a korg n5 music workstation. one side of my
It could be that you have a keyboard 'split' turned on but haven't allocated a voice / sound to one half of the keyboard.
See chapter 1 page 11 and chapter 3 page 27 of the manual available at the link below for a more detailed explanation
http://soundprogramming.net/manuals/Korg_N1_N5_Manual.pdf
Posted on Feb 02, 2011
Does this keyboard have a button battery inside?
Yes, just the same cmos battery the desktop computer use. easy to replace, located on the main control board.
Sep 06, 2016 | Korg M50 61-Key Music Workstation Keyboard...
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My corg m50 board not orking gm not ork
Your best bet would be to contact Korg directly. Here is the link to their USA support page
Contact KORG
Feb 11, 2015 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Korg M 50
Korg Support advises that they can either provide you end cap or direct you to a retailer. CLICK HERE
May 23, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How do i get a key to play repeatly on a korg microstation 61 key just by holding the key down?
No, synths don't have a repeat feature like computer keyboards. You have to keep playing it.
Mar 19, 2011 | Korg microSTATION 61-Key Synthesizer...
Where can I get the Korg m50 service manual or parts manual?
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
Feb 26, 2011 | Korg M50 61-Key Music Workstation Keyboard...
Korg KROSS-61 61-Key Workstation Keyboard/Synthesizer - Logo
370 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
