Can not connect to wi-fi
SOURCE: Wireless Connection failed
Did you make any hardware or software changes? You don't say.
Try seeing if your wireless radio is turned on. Most laptops have some kind of switch or Fn key combination that will turn off the wireless networking radio to save power. You might have inadvertently shut it off.
On the other hand, if it's a software thing and it only happened today, try using System Restore in Accessories --> System Tools and go back a day or two. If it's a software issue, that may resolve it.
Post back with any problems.
SOURCE: wi fi connection
Try to check on the device manager if the wireless adapter and the ethernet adapters were installed properly. If it appears with a questionmark, uninstall it and try reinstalling it without the ethernet cable connected.
If you are using Vista system, after installing the adapters, go to the network connections and just click on tcp/ip then click on properties. Exit from the window by clicking ok until all windows will be closed for the network connections. Reboot your pc and try if you can obtain a connection.
try to setup again wireless card's driver if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
SOURCE: I have an Acer aspire
This method will hard reset the wireless drivers back
to
default settings, but before you perform this remove power from the
modem and router for 2 minutes reconnect power and wait another 2
minutes for them to settle down.
Go to your laptop, right click "computer" select "manage"
and then "device manager", a list will populate, then click on the + sign next to "network
adapters" and right click on the wireless adapter and "uninstall" the
device, reboot the PC and wait for windows to detect the wireless
card and install the drivers for it, this will appear in the system
tray (bottom right hand side) when its done try to connect again.
Good luck
