I have 1 gb ram installed in my pc having 1.4 core 2 duo processor, this works fine on WinXP but when i install win7 32bit its performance come very slow, can any body tell that how i can speed up my computer.
Hi Muhammad Yasin, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What year is your PC?Hi Muhammad Yasin, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What year is your PC?
You can't post conmments that contain an email address.
IF YOUR BIOS CAN'T RECOGNIZE A NEW PROCESSOR AND STIL INDICATES YOU HAVE THE OLDONE, BUT YOUR COMPUTER WORKS FINE, YOU HAVE TWO OPTIONS: 1.Live with it. No harm should be done. Actually there is a faster procesor in your computer and it works. 2, Update your BIOS. You should find the proper BIOS update for your computer. If any error happens while updating your BIOS, you may "brick" your computer.. It will be converted to a nice decoration piece and conversaton object.
Ahhh.. just another possibility. sounds incredible, maybe you'll say that it's not possible, but maybe you made a mistake and used the old processor or you installed a similar processor to the one you had before?
YOU CAN'T WINDOWS 32X CAN ONLY USE 4 GB (1 GB TO THE SYSTEM).THAT LEAVES YOU 3 GB AND 4 USELESS GB. YOU NEED A 64X PROCESSOR TO HAVE USE OF 8 GB MEMORY.
Hi Trifon, you are detecting a known problem for 32 bit operating systems. The problem for those system is that they can manage maximum 3 Gb of RAM. If you want all of your RAM used you have to install a 64 bit operating system. Windows 7 has also a version for 64 bit as well as windows xp (but is not good supported) and windows vista.
It requires at least 2 gb ram and c2 duo or higher.
Be sure you have that min with your pc.
next you need windows cd.
insert it int drive and press F3 or any key to boot with cd.
It's then very simple just do as pc says.
In format using type choose NTFS
next just proceed as directed and you are done.
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry. ken
Minimum System Requirements OS – Windows XP or Windows Vista Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista) Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista) Video Card –256 MB** Hard Drive – 12GB Sound Card – DirectX 9.0c compatible * Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster. ** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required. Recommended System Requirements OS – Windows XP / Vista Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+ Memory – 2.0 GB RAM GPU – NVIDIA GeForce 8800 GTS/640 or similar
I believe it should work fine. Sony's site has good driver support for windows 7, and directions on installing Windows 7 on that machine. So it should work without any issues.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Personally i would recommend to upgrade ram then install win 7 Regards Uttam Windows 7 requirement If you want to run Windows 7 on your
PC, here's what it takes:
1 gigahertz (GHz) or faster
32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit)
or 2 GB RAM (64-bit)
16 GB available hard disk space
(32-bit) or 20 GB (64-bit)
DirectX 9 graphics device
with WDDM 1.0 or higher driver
whats your ram speed? if it reach to 1GB then you can install. but think twice coz' it will slow down your lapto.
If you want to run Windows 7 on your PC, here's what it takes: 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit) 16 GB available hard disk space (32-bit) or 20 GB (64-bit) DirectX 9 graphics device with WDDM 1.0 or higher driver
