Question about Universal EasyCAP USB 2.0 Audio/Video Capture/Surveillance Dongle
Realtek not visible to Roxio
Unable to record from internet. sound played by browser. browser not a choice in Roxio sound editor
I have had Roxio Creator 2011 for 3 years and have been able to copy many of my vinyl Lp's onto the system. However I have not used it for about 8 months and when I tried to 'record' some more LP's I...
If you didn't install the driver of the USB record player, it won't pick up all but the basic functions of the unit. try upgrading the driver of the LP usb player.
Nov 18, 2013 | Roxio Creator 2011
How do I record a you tube video using Roxio 10
If you want to download videos from YouTube, you can just use Leawo Free YouTube Downloader It is free and can perfectly download videos from YouTube. This is tutorial - http://www.leawo.com/flash/download-online-video.html
May 24, 2010 | Roxio Easy Media Creator 10 Suite
I have a Realtek HD audio driver on my Windows XP Media Center Edition version 2002 with SP3. I can listen to anything online and offline but I can't record anything using my Wave Pad sound editor or...
Open your control panel.
Click on Sounds and Audio Devices with the control panel in classic mode.
Click on the Audio tab.
Is Realtek HD Audio Input Device listed as the default device under Sound recording?
If not, select that from the drop down list and click Apply/OK.
Mar 18, 2010 | Gateway Computers & Internet
Error: unable to read certificate file . I am unable to remove software, install or repair it.
This is what I got from a forum
1. Fix registry permissions
a. Click on "Start" choose "Run", then type "regedit" and click "OK".
b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine".
c. Now click on the "+" next to "Software".
d. Right-click on the key (folder) called "Roxio" and choose "Permissions".
e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow".( This does not apply in win2000!)
2.
f. If you had to add those checkmarks, click on "Apply".
g. Click on "Advanced".
h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects".
i. Click "OK".
j. Click "OK" again.
k. Now close the Registry Editor
If this does not work, then download the Revo uninstaller and uninstall Roxio from that. Try to install once again and I think it should work fine.
Nov 17, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Shrill sound problem
If you have Roxio 9, remove it (and other copies of Roxio/Sonic) from the computer.
Remember: Roxio Creator 9 and Roxio Creator 2009 are NOT the same things!! Creator 9 is an old software application that Roxio does not support.
Mar 29, 2009 | Roxio Creator 2009 for PC
Sound card won't work with external input
Are you trying to record and listen at the same time? It doesn't usually work that way, the computer has to process and encode the audio signals before they can be listened to. Once you restore the computer, are you able to listen to the recording? If you have onboard sound, rather than a separate sound card, all the audio processing is done by your CPU. If you are trying to listen to the audio as it is being recorded, you are probably overloading the capabilities of the device and its shutting itself down. Try to record without listening. Also make sure you have the latest drivers. If it is onboard audio, check the manufacturer's website for updates. If you know that it is Realtek AC 97 (probably says so your manual), you can download new drivers from the Realtek website.
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
Universal EasyCAP USB 2.0 Audio/Video Capture/Surveillance Dongle Logo
76 people viewed this question
Top Universal Computers & Internet Experts
Lawrence Oravetz
Vebble
 Grubhead
Grubhead
Are you an Universal Computer and Internet Expert? Answer questions, earn points and help others
