Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: I had a Dell Inspiron
Yes, that's correct, you must replace the RAM memory module; is very easy just get a small screwdriver and open the small compartment on the backof the laptop, there is no need to open the entire cap. Also you can test each module to find out which one is failing
SOURCE: inspiron m5010 won't power on
Remove main battery and try again, next! have the power adapter checked for correct voltage, if okay! sub the ram memory one at a time and test, if nothing! the DC jack in the computer is a common issue, the laptop must be dismantled down to the motherboard level to address, at this point I recommend a professional to assess.
SOURCE: dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
all bullshits,,,,,,,,,,,
its a Processor related issue, there can be two reasons.
1- a bad processor or 2- the motherboard is not able to communicate the processor.
