Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Jun 17, 2014
Lavazza machine will not puncture coffee pods
  • Peter Flynn
    Peter Flynn Jun 11, 2018
    It seems to be leaking seals causing the pressure to fail. I'd replace the machine with a different brand designed to last longer.
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Jul 14, 2009
SOURCE: Gaggia Classic Spurts Everywhere
Hi there if your coffee is spurting out the sides it is because the group gasket is worn or has gone hard through use and now needs replacing. Basically when you twist your coffee handle on it doesn't always form a perfect seal and so the pressure causes the coffee to spurt out the sides. If you are not sure where to get parts get in touch with David at [email protected] and he will be able to sort you out.
All the best
LaPavoniBoy
Anonymous
  • 19 Answers
  • Posted on Nov 12, 2009
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Anonymous
  • Posted on Feb 16, 2010
SOURCE: lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Anonymous
  • Posted on Dec 27, 2010
SOURCE: Just need instructions to descale
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Anonymous
  • 3 Answers
  • Posted on Jun 05, 2012
SOURCE: need service on lavazza blue LB 2210
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
Lavazza Jolie Pod Coffee Machine, the water in the dispenser leaks out of the machine, and no coffee comes out of the coffee pod
Here are some possible reasons why the water in your Lavazza Jolie Pod Coffee Machine leaks out of the machine and no coffee comes out of the coffee pod:
  • The water tank is not filled properly. Make sure that the water tank is filled to the correct level. The water level should be between the minimum and maximum marks on the water tank.
  • The coffee pod is not inserted properly. Make sure that the coffee pod is inserted into the machine properly. The coffee pod should be inserted all the way into the machine until it clicks into place.
  • The coffee pod is clogged. If the coffee pod is clogged, the water will not be able to flow through the pod and into the cup. Try using a different coffee pod or try cleaning the coffee pod.
  • The machine is not descaled properly. If the machine is not descaled regularly, it can build up calcium deposits, which can prevent the water from flowing through the machine properly. Try descaling the machine with a descaling solution.
  • The machine is defective. If you have checked all of the above and the problem persists, then the machine may be defective. In this case, you will need to contact Lavazza customer support for further assistance.
Here are some additional tips that might help:
  • Use fresh, cold water. Stale or warm water can affect the taste of the coffee.
  • Use a good quality coffee. Cheap coffee beans can make the coffee taste bitter.
  • Grind the coffee beans to a medium-coarse grind. A too fine grind can make the coffee taste bitter, while a too coarse grind can make the coffee taste weak.
  • Clean the coffee machine regularly. A dirty coffee machine can make the coffee taste bitter.
I hope this helps!
Lavazza espresso point coffee won't brew coffee but water comes out of steam pipe.
  1. Make sure the water tank is filled and properly seated in the machine.
  2. Check the water flow from the steam pipe. If the water flow is strong and consistent, it is possible that the coffee brewing mechanism is clogged or malfunctioning.
  3. Check the coffee pod for any damage or debris that may be preventing it from brewing properly.
  4. Make sure the machine is properly calibrated and that the coffee brewing settings are correct.
If none of these suggestions fix the issue, it is possible that there is a deeper problem with the machine that may require the help of a professional repair service or the manufacturer to diagnose and repair.
Why doesn't machine puncture coffee pods?
SADLY NO CLUE AS DO NOT KNOW ALL COFFEE MAKERS WORLD WIDE
Keurig is spitting coffee grounds into the coffee cup and into the area around the pod when it dispenses coffee. How do I fix it.
Sounds like someone Bent the peice where the POD is Punctured.. or the Hindge on the Pod Holder is bent..let us know what you find !!
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
1helpful
3answers
Need service on lavazza blue LB 2210
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Top Lavazza Coffee Makers & Espresso Machines Experts
john h
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
