Where can I download the instructions for setting the timer on the Malibu ML600TW
Http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#manual
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: how to set timer on malibu box
Also, make sure to set the dial for the correct time of day.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have a Malibu 8100-9045-01
Go to the link below to see how to set. Click on the 5th one down to set time and day.
http://www.malibulights.com/customer_service/knowledge_base/transformers_faq.aspx
Good Luck
SOURCE: THE TIMER DOES NOT WORK , NEED TO REPLACE IT WHERE
I've done a lot of reading and research on Malibu
No replacement parts for Power pack, or schematic >> Malibulights.com shows replacement lights and replacement power packs
Manual for Malibu 600 Watt power pack
SAVE the pins off old power pack and see if they match pins on new power pack ... because you can't find pins on the internet
When the power pack goes bad or you lose the pins, then you buy another power pack
Things to remember:
Match number of lights to power pack wattage
30 - 20 Watt bulbs => 30 x 20 = 600 Watt power pack
Replace bulbs as soon as they burn out, or other bulbs will burn out quickly, and I think it causes power pack to burn out sooner too.
Up-vote if this helped. Thanks for the feedback.
SOURCE: Lost instructions to set timer
Your instruction manual might appear on following link:
http://malibulights.com/customer_service/owners_manuals.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: Need red plastic timer clips for my ML600TW.
Open following link for ML power
pack trippers, plus troubleshoot, plus tips to keep power pack from burning out,
and warranty:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
