Question about Canon DR-9080C Path-Through Scanner
Missing pages with print only on the bottom of page
This may be because you have selected to have the scanner skip blank pages in the software, and it is thinking that the page is blank. Try deselecting that option and see what happens...
Kris
Posted on Jun 18, 2014
SOURCE:
How many pages in a pdf download for Necchi Instruction manual for Necchi Model 3101 FA?
when the down load opens up on the screen, in a small tool bar at the top of the pdf section there are areas that show page numbers , zoom in / out expand size etc the number of pages will be there shown as 1 /24, or 50,or 600 etc ( 1 / of the number of pages in the down load )
if you click on the scroll bar on the right of the page proper and scroll down , as you pass each page break it shows the next page number
if you scroll down the page you will come to a contents list and that will also show the number of sections in the manual and that will indicate how many pages you can expect
to reduce paper wastage from a normal house hold printer when you print from the printer logo in the bottom right of the page you get the printer up and where it says print all , change that to print odd pages ( or even pages ) or or print pages and this is where you put in the pages that you want printed -such as 1,3 5, 7 etc
when the print run is finished put the whole lot of printed pages turned around and back in the printer then print the page numbers that you missed on the first print run this will result in a booklet with printing on both sides of the page and reduce the number of sheets used in printing
Nov 07, 2015 | Necchi Sewing Machines
Bottom of borders missing
Check to see if your paper setting is A4 instead of 8 1/2 x 11. If so change it.
Jul 04, 2010 | Dell 924 All-in-One InkJet Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Hp photosmart c4580 (new) is not printing bottom line of page, also not printing centrally it misses words down the right hand side connected to advent windows vista can you help
Try printing a test page, if the problem appears there too, it could be a print head problem. But try a new ink cartridge first, to make sure that's not whats defective.
Since it's new, you should consider exchanging it while you can.
Sep 19, 2009 | HP Pavilion dv6000z Notebook
Test page prints fine, but nothing else does
You need a new printhead, QY6-0049-000 around $40.00. Your printhead has worn out or plugged nozzles and cleaning won't help.
Jul 09, 2009 | Canon i860 InkJet Photo Printer
HP 1410v will not print.
The printer is printing an alignment page. Take that alignment page and put it on the scanner part of the printer and then press the scan button, that will align the print heads
Nov 12, 2008 | HP PSC1410 Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Laserjet 4l missing bits
If you haven't already, get a driver here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15034&lang=en&cc=us&prodTypeId=18972&prodSeriesId=25486&taskId=135 and install it over the old one. If text is missing at the bottom of the page, this usually means that the application is attempting to print outside of the printer's printable area. Most printers, including HP LaserJets, can not print right up to every edge of the page. Adjust the bottom margin upwards in Word. Usually, in Print Preview anything outside of the printable area as known by the printer driver will not be displayed. This is not guaranteed to work since there are many way things can go quirky, but it's usefull to try. Can't tell you much about the alignment though, hope you work it out.
Apr 10, 2006 | HP LaserJet 4L Printer
Canon DR-9080C Path-Through Scanner Logo
64 people viewed this question
Clive
Clive
old marine
old marine
Ekse
